Votes
0
Product:
iClone 6
Version:
6.53
Status:
Active
Issue 2002
筆電的休眠導致 iClone 當掉,iClone 的輸出導致筆電重開機。兩者互害。
如果在 iClone 開啟的狀態下放著筆電不動。等筆電進入休眠後,再重新喚醒時, iClone 就當掉不見了。重新啟動 iClone 會要求是否儲存上次當掉的檔案。
但是若今天是在輸出階段,筆電進入休眠或省電狀態,要再喚醒筆電,則作業系統會等非常非常非常久(黑畫面)才啟動,而且,啟動的方式是重新開機。輸出的東西也沒有了。這樣就非常嚴重。很糟糕。
筆電是 ASUS 的,作業系統為萬惡 window 10。雖然不好也沒有爛到可怕就是。
OS: Windows 10
  •  1
  •  1841
Bug
Submitted byanonym0214
COMMENTS (1)
Google translate:
The laptop's sleep causes iClone to go down, and the iClone's output causes the notebook to restart. The two harm each other.
If the iClone is turned on the state of the laptop does not move. Such as laptops into sleep, and then re-awaken, iClone when the out of sight. Restarting iClone will ask you if you want to save the last file you deleted.
But if today is in the output stage, the laptop into the sleep or power state, to wake the laptop, the operating system will be very, very long time (black screen) to start, and start the way is to reboot. Output of the things are gone. This is very serious. very bad.
Laptop is ASUS, the operating system for the evil window 10. Although bad is not rotten to terrible is.
