Votes
0
Product:
iClone 8
Version:
8.02
Status:
Closed
Issue 8761
3D CONNEXION SPACE MOUSE PRO
Space Mouse Pro from 3D Connexion in CC4 work perfectly but not in Iclone 8. I have update to Iclone 8.2 and I have update the last driver to Space Mouse Pro, and it works perfectly in CC4 but not in Iclone 8 in any updated version, when I try to move the Space Mouse the screen start to move in all directions so quickly and I can´t stop it. Any solution for that??
OS: Windows 10
  •  9
  •  2112
Bug
Submitted byGARCIAGA
1 2
COMMENTS (9)
WeiChien(RL)
Hi Mikegreenway,
You should be able to connect the buttons on your device and iClone functions via 3DConnexion setting panel.
There is a tutorial to describe it.
https://youtu.be/ns9gooo81BQ?t=206
Mikegreenway
Molly,
I'm a little confused, the solution allowed me to use the spacemouse to move around the selected object correctly in iClone 8, but how do I assign short cuts to the buttons on my space mouse pro?
Thanks for your help!
Mikegreenway
Use the Keyboard profile and forget about the space mouse profile, right?
Feedback Tracker Admin
Hi Mikegreenway,
You can set hotkey in Hotkey Manager panel from Edit menu.
Molly
Reallusion
Mikegreenway
I had the problem with a 14-year-old SpaceNavigator also, I found that that model was no longer supported by the new drive. That's why I have a new one.  I'm not sure about your case but I thought I'd let you know.
Good luck.
GARCIAGA
Thanks a lot. I choose a new profile in Hotkey Manager, and now it works ok!!!
Hi GARCIAGA,
Greate!If you have any question,please let me know.Thanks.
Molly
Reallusion
Mikegreenway
Here you are
Mikegreenway
Wow! thanks so much for your timely and effective solution.
Hi Mikegreenway,
I'm very sorry, this is a function limitation, we can't judge all devices.Please choose JoyStick in drop down menu, and delete all hotkey.Then try it again.
Molly
Reallusion
1 2
