3DX crashes when removing sub-props on nodes that have been made into sup-props twice
STEPS TO REPRODUCE 1. Launch 3DXchange 6 2. Load iClone embed content Fan 3. Navigate to Scene Tree > Fan > Base 4. Go to Modify > Node, click “Make Sub-Prop” 5. Then select second “Base” on Scene Tree and click “Make Sub-Prop” again 6. Select the third “Base” on Scene Tree, go to Modify > Node, click “Make Sub-Prop” and “Remove Sub-Prop”
ACTUAL RESULT Program crashes
EXPECTED RESULT Program can work normally
OS: Windows 10
0
2212
Submitted byFeedback Tracker Admin
COMMENTS (0)
You are going to edit a submitted issue. This issue will be changed to private draft mode until you click submit again. Are you sure?
