Votes
Product:
3DXchange 7
Version:
7.4
Status:
Active
Issue 6089
3DXchange7 crashes without any message
When I import any DAZ gen3 or 8 character into 3DXchange7 it will load fine and display. When I try to export or click "Apply to iClone" the program is busy for a while and then crashes. There is no error message, it just disappears.
GPU is RTX2080 with driver 26.21.14.3086
DAZ 4.11.0.383 Pro 64-bit
3DXchange 7.4.2515.1
I tried unmorphed default figures, with and without animations and using various FBX versions. I have tried to follow the online manual to the letter, but 3DXchange crashes each time.
Please fix your programs so they don't crash, particularly without any messages.
OS: Windows 10
  •  5
  •  1619
Submitted byccl_51
COMMENTS (5)
digitrevx
Can your software maybe not crash to desktop when importing any modern fbx file into it?
Aniquate
I Used the fbx bin 2011 Export switched to 2012 and it worked. One of May Frustration Points was to Export head meshes and try to reimport them, without Changes it causes Errors. Maybe some Workaround needed.
Thanks
Feedback Tracker Admin
Hi Aniquate,
Can you provide your FBX file ( FBX 2011-Binary )to us and capture a screen shot about Daz Export FBX Option panel?
Molly
Reallusion
Hi Aniquate,
Can you provide your FBX file to us and capture a screen shot about Daz Export FBX Option panel?
Molly
Reallusion
Hi ccl_51,
Can you provide crash dump file & startup log file to us?
Molly
Reallusion
Hi ccl_51,
We can't reproduce this issue.  Please provide crash dump file & startup log file to help us identify the problem.Attach the file in your next comment.
Download the zip file with the link below, inside the zip you can find the description about how to generate the startup log and crash dump.
https://goo.gl/YgVYhF
Molly
Reallusion
Aniquate
I got the same Problem gen 3/8 male & female, base model no hairs
Hi Aniquate,
Please provide your FBX file to us. Attach the file in your next comment. If the file size is larger than 10MB, you can use cloud services such as Google Drive, Dropbox or OneDrive to make the files available to us and put the link in your comment.
You can use Private Comment if you want to keep it private.
Molly
Reallusion
Hi Aniquate,
Your help is highly appreciated.
Molly
Reallusion
