3d exchange wont import a teselated prop from ic 6 correctly
the morphed prop always imports into 3d exchange (from ic6) in its original state and is un-useable to export with the modified teselation mesh... I might be missing a step but I have searched for a solution and just cant find it
OS: Windows 7
2328
Submitted bySpiderTec
COMMENTS (1)
Feedback Tracker Admin
Hi phantasma8,
In order for us to fix the issue, we need to be able to reproduce it. For this we need a precise description of what you did so that we can clearly follow your actions and recreate the same situation.
Here is an example to help you get started:
STEPS TO REPRODUCE
1. Click the product’s icon on the Desktop or Start Menu
2. Wait for it to launch
3. Navigate to Content Manage > Project
4. Select a random project and click on “Apply”
5. See whether that project can successfully be applied
ACTUAL RESULTS
The project can’t be applied
EXPECTED RESULTS
The project can be applied
Thank you very much for your understanding.
You are going to edit a submitted issue. This issue will be changed to private draft mode until you click submit again. Are you sure?
