Votes
0
Product:
Cartoon Animator 5
Version:
5.32
Status:
Assigned
Issue 11870
APNG props not hiding or playing 1st frame again
1-create prop, select apng, loop infinite. add flag to start and end frame, export motion.
2-Puppet stage + eye, always hide, defualt pin, add motion, uncheck mimic
preview: prop plays, right before it turns off it plays frame 1 again
OK infinite loop seems to be issue
1-create prop, select apng, loop ONCE. add flag to start and end frame, export motion.
preview: prop plays and stays at last frame never turning off
OS: Windows 11
  •  6
  •  1045
Bug
Submitted byjaygaitchison
1 2
COMMENTS (6)
jaygaitchison
a late but very thankyou
jaygaitchison
this is the length of all the smoke motions, how are they 2000 frames?
Feedback Tracker Admin
Private Comment
jaygaitchison
that would make sense.  I did collect clip, export: only one loop (around 20) not 2000 frames tho. I will try again and report back
thanks allen+team
Hi jaygaitchison,
After the RD team checked your project, they found that since the Motion Card has 2000 frames, it appears not to return to the Default Motion's Hide state because the Motion Card continues playing after being triggered. You can try adjusting the length of your Motion Card to resolve this issue.
The ctAnim file exported through Smart Content Manager will contain a Motion Clip with the same length as in the project. You can try selecting the desired range using Collect Clip, then right-clicking to export the Motion. Afterward, replace your original Motion Card with the newly exported ctAnim file.
Allen
Reallusion
jaygaitchison
if i add a empty frame at end
it works
1 2
