Votes
0
Product:
iClone 6
Version:
6.53
Status:
Active
Issue 2193
Alembic Import
This should have implemented at the time they implemented Alembic Export. It's beyond irritating that you implement only half a solution. Alembic import would allow us a much greater flexibility in what we choose to render, for instance, a sequence can be animated in iClone, the motion imported to DAZ, and the character could be returned to iClone via alembic with a much greater presentation because you're able to take advantage of DAZ's JCM's. You've given us half a solution. If you allow alembic export, you should allow alembic import.
OS: Windows 10
  •  2
  •  2460
Submitted bywill2power71
COMMENTS (2)
To add to this suggestion, this was recently discussed in the context of importing simulations from Houdini, which would provide quality waves for example.
A good suggestion, which has also been discussed on the forum, but I don't think there is a need for the accusatory tone as that doesn't really make for a stronger case.
