Votes
0
Product:
Character Creator 3
Version:
3.32
Status:
Released in 3.4
Issue 7342
Altered character recall
Character created in CC3 and later saved. When recalled, it appears altered. I have seen this type of defect that is proposed with one type of shirt and not another. I have performed the following actions suggested by your assistance but without positive result:
"I would suggest:
Run Windows Update.
Install the most recent driver for your graphics card.
reinstall the content pack if you have not already.
reinstall CC3 using this clean method. Your content folders are safe during this process.
Uninstall Character Creator 3 and CC3 Pipeline Extension.
Check this directory for any CC3 leftovers:
C:\Program Files\Reallusion
Find this directory: C:\Users\your name\AppData\Local\Temp
Delete this folder: CharacterCreator3Temp
Note that AppData is a hidden folder, and you may need to set "Show hidden files and folders" for Windows
Also note that "your name" is your user name on your computer.
Download and unzip this registry cleaner. Double-click to run it. If it does not find anything, then Windows took care of it.
http:\\ftp.reallusion.com.tw\reallusionsupport\CharacterCreator3_Registry_Remover.zip
This is optional. If you want to be sure your system is as clean as can be, you may want to download and run Jetclean. It's a registry cleaner.
http://www.bluesprig.com/jetclean.html
Restart your computer.
Install the current version of CC3 and CC3 Pipeline Extension from the Hub, or downloaded from your Reallusion Account. Install both parts before running."
I await your news.
OS: Windows 10
  •  7
  •  3729
Bug
Submitted byemypippo
1 2
COMMENTS (7)
emypippo
Good morning
I enclose a further problem that I hope will help solve the problem.
I hope for an update.
emypippo
Here are your questions and their answers:
Did you modified the skin weight of this T-shirt before you apply to character?
Yes
If you apply the Plain Base in Template tab then save the project, did this project still occur the same issue?
What do you mean by Plain Base in Template?
If problem still exist, please provide this folder within your template install path : ...\Reallusion\Template\Character Creator 3 Template\ContentPatch, also your plain base T-shirt.
You must excuse me but it is not clear what I should do.
emypippo
Private Comment
Feedback Tracker Admin
Hi emypippo,
Q1 : What do you mean by Plain Base in Template?
Template is where you install this content. Cause we use the same T-shirt but can't reproduce the issue.
So, I want to check if the original T-shirt in your template folder doesn't have the issue or not.
Q2 : You must excuse me but it is not clear what I should do.
Please go to template folder, the default install route is ( C:\Users\Public\Documents\Reallusion\Template\Character Creator 3 Template )
And find the folder calls "ContentPatch", then zip this folder and upload to cloud service such as Google Drive, and attach the download link in your next comment.
You can also set that comment as private.
Thanks for your help!
Calvin
Reallusion.
Hi emypippo,
Thanks for your feedback.
Calvin
Reallusion.
emypippo
Private Comment
Melvin_RL
Hello emypippo ,
Can you provide your project to us to help us identify the problem?Please attach the file in your next comment. If the file size is larger than 10MB, you can use cloud services such as Google Drive, Dropbox or OneDrive to make the files available to us and put the link in your comment. You can use Private Comment if you want to keep it private.
Your help is highly appreciated.
Melvin
Reallusion
1 2
