Votes
0
Product:
Cartoon Animator 5
Version:
5.33
Status:
Not a Bug
Issue 12487
Asset Motion Missing
Hello, I see some tutorials with the 'spider' actor, and showing how to use Motion Pilot, for example.
However, regardless of updating and downloading all the packs, I don't see the actual motion of the spider.
A large part of my project was based on this motion, and CA5's easy to transfer motions. And I have built about 30% of my project already, which has taken a couple of weeks, only to find out that the motion of the Spider Walk doesn't even exist.
I am not animating all the leg motions by keyframing as that defeats the purpose of why I am using the software- for it's faster animation.
There are courses and official tutorials with this motion- where you easily just drag the spider onto the viewport and can move it around with motion pilot of set a path for it, but that motion is missing!
I've downloaded the latest Puppet Path, which is where that asset is in, and I see a bunch of other motions- EXCEPT the one I got this for.
Is there a way to update that in your packs and release ? Otherwise this has been a big upset.
Thanks.
OS: Windows 11
  •  2
  •  244
Submitted byvirtuarystudios
COMMENTS (2)
Feedback Tracker Admin
Hi virtuarystudios,
There is currently no spider walking motion available in Free Resources. You can directly use the spider character from the “Puppet & Path” pack in Free Resources. By using Motion Pilot, you can easily create a walking animation.
Alternatively, you can record a spider walking motion yourself. After recording, go to the Timeline, use Collect Clip to select the desired animation range, then right-click on the Collect Clip track and choose Export to save the motion. The exported motion can then be applied to other spider characters.
Allen
Reallusion
virtuarystudios
Answer:  Apparently I don't know where to look for things well, yet.  I don't even remember where I saw it but I was able to add the "walk" motion and I think it was only in a Motion Pilot window?  Anyhow, it's still a little confusing because I thought "motions" would appear in Animation Folder in the Content Manager as a type of motion already created, that you could just drag and drop easily onto similar objects, and more importantly on the object that it was created for.
I still don't see it where other animation motions are, nor under the actual asset's folder in CM, but I got it to work thru MP if I recall correctly.
So..issue resolved?
Thank you.
