Votes
0
Product:
iClone 7
Version:
7.91
Status:
Active
Issue 7955
Background Power Performance
When i work on a cpu angry project the fans spin a lot. Of course this is normal. But if I get up from the machine for a few minutes i usually not turn off the computer. Would be fine a power performance function in the background where iclone turning into power save mode if nobody not use the computer after 5 minutes. It's not an important function, but environmentally friendly. The internal Windows power save mode some times not good choice so i hope you can implement this.
OS: Windows 10
  •  2
  •  891
Submitted byFreddymusic
COMMENTS (2)
Freddymusic
This is exactly what happens when I minimize the window, but it is a half solution. Of course I can live with that, so it is not an extremely important feedback from me just an opinion.
Feedback Tracker Admin
Hi,
Currently iClone has the "Reduce Idle Load" , it is similar to the function you mentioned.
GPU|CPU load can be released when your operation events do not happen in the view-port, eg. Minimize iClone window, or operate in other software
you can see the online manual about this feature:
https://manual.reallusion.com/iClone_7/ENU/Content/iClone_7/7.6/04_Introducing_the_User_Interface/Reducing_GPU_Load.htm?Highlight=reduce%20idle%20load
Thanks,
Joanne
