Votes
0
Product:
iClone 8
Version:
8.65
Status:
Closed
Issue 12443
Batch Render wants to save projects between renders - click "no" and no more renders happen
In the latest version of iClone 8.65, the Batch Render tool now only renders the first of the batch.
Steps to reproduce:
1. Open iclone
2. From the Render menu, select Batch Render
3. Select a folder with multiple iproject files
4. Batch render
Expect behaviour
All iProjects files that are discovered are rendered
Actual behaviour
First one renders, then a dialog box appears asking if you want to save the project, options Yes, No, Cancel. Clicking No stops any further renders.
System:
Windows 11 Home.
OS: Windows 11
  •  1
  •  279
Bug
Submitted byade.p
COMMENTS (1)
Feedback Tracker Admin
Hi ade.p,
Regarding the "Save Project" dialog interrupting your batch render:
Reason:
This happens because Batch Render processes the list by opening each project sequentially. When it finishes rendering one project and prepares to load the next one, it must close ("discard" from memory) the current project.
The message "The current project will be discarded" simply means the system is about to close the file, and it is asking if you want to save any changes before doing so.
Solution:
   To prevent this from stopping your queue, please check the "Ignore warnings" option in the Batch Render panel.
      Enabling this option will suppress these prompts (defaulting to "No/Discard"), allowing the batch process to continue automatically without interruption.
      This does not affect or corrupt your original project files. However, if you want to be extra safe, you can always backup your project files before starting the batch render.
For more details on the settings, please refer to our online manual:
https://manual.reallusion.com/iClone-8/Content/ENU/8.0/80-Export/Batch_Rendering.htm
Best regards,
Kayla
Reallusion
Hi ade.p,
I hope you are doing well! I am writing to quickly follow up on your ticket regarding the Batch Render interruption issue in iClone.
Were you able to try checking the "Ignore warnings" option in the Batch Render panel as we suggested in our previous reply?
Please let us know if this allowed your batch rendering process to continue smoothly without the "Save Project" prompt. If you are still having any trouble with this, we would be happy to assist you further!
Thank you for your time.
Best regards,
Kayla
Reallusion
