Votes
0
Product:
Character Creator 3
Version:
3.04
Status:
Closed
Issue 6145
Bump/normal/shininess and metallic maps not loaded for avatar skins
It used to be Transformer would correctly locate the bump/normal/shininess/metallic maps for skin but it no longer works that way. I can't get ANY avatar to correctly load in the skin maps anymore.
OS: Windows 10
  •  12
  •  5293
Submitted byKelleytoons
1 23
COMMENTS (12)
Thanks, Calvin (and no worries -- I've been up to my neck in alligators here).
Feedback Tracker Admin
Private Comment
Or maybe you could just give me the right Lua file (since it appears to be all I'm missing).
And, again, they need to have version numbers internally (just sloppy programming not to have them).
Hi Kelleytoons,
CC 3.04 release date was 2019/02/21, and CC 3.03 was 2018/12/05, but I've check both AP's DazTexture.lua all have these lines.
So, maybe you can re-download the correct installer via Reallusion Hub or Member page and install it again to see if you can get the proper files.
Thanks for your help!
Calvin
Reallusion.
Yeah, those lines aren't there (can I make a very simple recommendation?  Please use internal designations as to what version of your Lua files are what.  My DazTexture.lua has no such designation.  I always start my Lua files with, say, #Version 1.01 and then even if they aren't dated we always know what version is what).
My DazTexture file is dated 12/4/2018.  So, latest version of CC3 installed (according to Hub) but pretty clearly I don't have the version of this Lua file you have.
1 23
