Votes
0
Product:
Character Creator 4
Version:
4.52
Status:
Released in 4.6
Issue 11690
CC 452 Building Morph Slider Cache on Each Program Start
CC 452 Building Morph Slider Cache on Each Program Start even it says "One time operation" on the Logo while starting the program.
CC could start faster if this would not happen on each start. IIRC this did not happen on earlier versions like 433.
Screenshot cant be taken because the Text indicating this does not appear in a screenshot for unknown reasons.
OS: Windows 10
  •  5
  •  642
Submitted byK_Digital
COMMENTS (5)
K_Digital
I monitored what windows does in that moment, it appears that CC locates thousands of ccsliders on each start.
If you provide me with info where the slider cache should be located i can have a look if it exists at all.
Feedback Tracker Admin
Understood. I will relay the situation we discussed to our dev team and ask them to investigate and address the issue.
Thank you.
Tina
K_Digital
The file does exist (more then 20000 entries) and CC renews it when shutting down. (On start it scans for all 22000 ccliders again)
Someone in the forum https://discussions.reallusion.com/t/character-creator-4-52-official-issues-thread/12824/52?u=k_digital
says this is normal.  I thought (and others as well) "one time operation" is meant to built a cache file
that CC will refer on next program start (in order to start faster) , not when creating a character like said in the forum.
Could you make a statement on this ?
Private Comment
K_Digital
Hello, i de and re installed the characters pack without suscess, the message still appears on each program start.
K_Digital
ooops i replied in the wrong window i guess, please read the other reply as well. Thanks
K_Digital
Hello Tina,
When i start CC it loads an empty scene.
Okay, thanks for your help.
Our engineer mention that if setting a default project with a character may cause this issue, could you check if your default project is empty scene or include character?
If it's caused by the default project, this will be fixed in future version.
Thank you.
Tina
Hello, thank you for your report.
We are currently unable to reproduce this issue in our environment.
However, you can try reinstalling the "Characters" pack under Content > Free Resource, as it contains a large number of morph sliders.
Rebuilding the related cache might help resolve the issue.
If the issue persists, please let us know.
Thank you.
Tina
WesleySales3d
I also believe it should be a one-time operation. The cache would be saved somewhere locally and loaded every time CC4 needed it. Increasing the speed of program startup.
K_Digital
Screenshot taken with a camera.
