CC's full Body export via OBJ to 3DXchange fail to link to the teeth textures
STEPS TO REPRODUCE 1. Launch Character Creator 1.52 2. Navigate to Menu > File > Export to Obj > Nude Character 3. Select “Full Body” on Obj Exporter panel, then click Export button 4. Launch 3DXchange 6, load the exported Obj file 5. Only select “CC_Base_Body Mesh” in Scene Tree 6. Check the character's teeth
ACTUAL RESULT Diffuse texture is missing
EXPECTED RESULT Diffuse texture won't disappear
NOTE It doesn't occur in Character Creator 1.4
OS: Windows 10
0
2449
Submitted byFeedback Tracker Admin
COMMENTS (0)
You are going to edit a submitted issue. This issue will be changed to private draft mode until you click submit again. Are you sure?
