Votes
0
Product:
Character Creator 5
Version:
5.06
Status:
Released in 5.12
Issue 12508
CC5 Tearline detail error
The tearline for CC5 characters does not function correctly. When imported into UE5, any changes made to the tearline in CC5 are not reflected. Furthermore, adjusting Roughness or Opacity values in a Material Instance within UE5 produces no visible effect.
https://youtu.be/F8JwyqW_B1c
Please check the video.
OS: Windows 11
  •  5
  •  296
Submitted bygokomu
COMMENTS (5)
gokomu
Hi.
Changing the Translucency Pass setting to After DOF in RL_Tearline_Plus, the master material for Tearline, fixed the issue.
In Auto setup, this setting defaults to Before DOF.
gokomu
Sorry. I've approved your access.
Feedback Tracker Admin
Hi gokomu,
I'll need access to your drive.
I've sent a request.
Thanks.
Steven
Reallusion
gokomu
Hi Steven.
Thank you for your reply.
I tried again, but it still didn't work. Only GIBRO's tearline is visible; the tearlines for the other template characters cannot be seen. Could you please check the UE project file and the CC5 FBX?
When I check in the Skeletal Mesh Editor, the tearline definitely exists. However, I'm not sure if it's a positioning issue, but unlike GIBRO, the tearline is not visible.
①https://drive.google.com/file/d/1d-o8zz2a1sJy5DPsQ5FBfCXF3cGuo-TP/view?usp=sharing
②https://drive.google.com/file/d/1-PQdcVLxVX_CoeIg6vUfhtJUbRWucSmr/view?usp=sharing
Hi gokomu,
I seemed to have problems reproducing this issue (like video below).
Tearline works fine for me. It'll appear if you take a closer look (it's not that obvious in UE compare to CC).
If your tearline doesn't show up after a closer inspection, please comment below and provide us your UE project and FBX exported form CC.
Thanks!
Steven
Reallusion
