Votes
Product:
iClone 8
Version:
8.7
Status:
Assigned
Issue 12466
Camera and roating without camera is not center offset any object
I just updated ICv8 and now when I select any object and try to rotate it goes way off to the sidees and dies not rotate on the center regardless if the pivot point is in the center of the object, even if I add a camera or in preview camera the center is ignored to roated in viewport, this is unusable, all I can do is manually rotate an object but that messes up the scene. I have tried all options and settings I could find. I would like to make some image sequences for a project but now it is brokenj to get the shots I would like in a scene.
Side note:
Update I found holding the Alt key with the right click mouse works, but the right click on the mouse is way off cener and is unusable
OS: Windows 11
  •  2
  •  268
Submitted bySpiderTec
COMMENTS (2)
SpiderTec
I found a solution I will post an image of the settings in preferences that worked that brought back the original settings. I noticed the Fly Cam has to be Checked for this to work
Feedback Tracker Admin
Hi SpiderTec,
Thanks for your Feedback,
The issue arises because version 8.7 added the feature of launching Fly Cam with a right-click. To change the default Hot Key, you can adjust it in Preferences.
JoePan
Reallusion
