Votes
4
Product:
iClone 8
Version:
8.0
Status:
Assigned
Issue 8456
Cannot effectively resize areas of the program
Regardless of what scaling setting / compatibility setting I use, iClone's dockable areas take up too much of the screen when at 4K resolution, even when they prevent me from shrinking them any further.
I have tested setting my Windows DPI scaling down from its recommended 250% to 100% and the UI does seem more reasonable, but am I expected to have to do this for this one program when any other that I've used handles high DPI without issue?
OS: Windows 10
  •  7
  •  2452
Submitted byChaosCrazed
1 2
COMMENTS (7)
ChaosCrazed
Yes, setting display to that resolution does work, but I find it strange that iClone and Character Creator are the only applications that require this kind of workaround..
Feedback Tracker Admin
Hi ChaosCrazed,
Thanks for your reply.
If you set the display resolution down to like 1920 x 1080, then restart the IC8 again, will it better?
Thanks for your help!
Calvin
Reallusion.
ChaosCrazed
I've updated to 8.01 and still cannot change the checkbox the admin mentioned..
AncientWire
If I have Motion Director in one of the stacks, then it won't resize.  If it pull it out of the stack, I can resize the rest of them then put Motion Director back in.  I
ChaosCrazed
I've checked in the menu you mentioned, but that checkbox is not allowing me to toggle it (see attached screenshot)
1 2
