Votes
0
Product:
Character Creator 5
Version:
5.06
Status:
Closed
Issue 12501
Casula20 TEXTURE ADJUSTMENTS error (Support TicketID : 268601)
This is the issue I discussed with Rampa from Customer Support.
Regarding the buggy texture adjustment for the Casual20 Regular Fit Trousers. Support TicketID : 268601
Please fix it.
First, could you please take a look at the ①video? Here, I'm trying to change the material for each color ID. However, only the buttons on the trousers with the Colour ID green change properly; the material doesn't change for the other parts.
When I try the same method with the Denim Maxi Skirt, the material changes correctly.
I also tried changing the texture of the color ID to different texture.
But for some reason, the material change only applied to the green channel, and the change didn't apply to red channel.
Please check the video②
https://youtu.be/yn-c8om6O10
https://youtu.be/Y3OKq_xdKLA
OS: Windows 11
  •  2
  •  173
Submitted bygokomu
COMMENTS (2)
gokomu
Hi Kayla.
Thank you so much for the detailed presentation.
I was able to successfully change the material using the method you taught me.
I apologize for the inconvenience, but could you please take a look at issue 12522?
 I've been struggling with this problem for the past few weeks.
 https://www.reallusion.com/FeedBackTracker/Issue/Character-overlap-issue-when-render-simulate
Thank you.
Feedback Tracker Admin
Hi gokomu,
Thank you for your inquiry.
I have attached a presentation file for your reference. The file outlines three different methods you can use to adjust the textures and resolve your issue.
Please review the attached presentation and let us know if it helps.
presentation link:
https://docs.google.com/presentation/d/17hQjOZCURIX3D3biBued_aTaOuWJf49yY3cj4Ce0CNw/edit?slide=id.p#slide=id.p
Best regards,
Kayla
Reallusion
