Votes
0
Product:
Character Creator 2
Version:
2.0 Beta 1
Status:
Released in 2.0
Issue 1962
"Clear" unused channels option for Appearance Editor breaks export to iC6.5 format
The steps detailed below will cause CC2 to locking up and stop responding when you export to the iC6.5 format.
PREPARATION STEPS:
1) Start a brand new project, using the default nude character
2) Open the Modify panel (if not already open)
3) Select an eye (CC_Base_Eye)
4) Open the Appearance tab of the Modify panel (the eye should still be selected)
THE CRUCIAL STEPS:
5) Activate the Appearance Editor
6) Select the >>CLEAR<< option for unused channels
CONTINUING WITH THE STEPS:
7) Edit the eye... I changed the Iris to a vibrant green color
8) You may Unload the Appearance Editor or leave it active, that doesn't matter
9) Export iAvatar
10) Select the "Character Creator 1.5 & iClone 6.5" format, leave all other options at Default values
11) Click the "Export" button
RESULT:
CC locks up and stops responding
DESIRED RESULT:
It should export the file.
OTHER INFORMATION:
a) In step #6 above, select the >>>KEEP<<< option, and the export will be successful.
b) In step #10 above, select the "CC2.0 for iClone (Beta) & iClone 7.0 (Beta)" option, and the export will be successful
c) EITHER "a" or "b" will make it successful, you don't need to do both
OS: Windows 7
  •  2
  •  4125
Bug
Submitted byjustaviking
COMMENTS (2)
Kevin.S
I opened CC 2.0 and with in about 30 second I got a crash CC has stopped working......
Following the steps outlined, Character Creator crashed on my Win 10 Pro system.
