Votes
0
Product:
3DXchange 7
Version:
7.8
Status:
Active
Issue 7770
Crashes on expression editor
each time i try to set an expression it crashes
wasnt like this in previous version
also that happens when i try to add morphs on a part of the body
please fix this
this is major :(
and im in a middle of a project
please can you give me the beta version of ic rc3 and 3dxchange? i deleted them when i updated to ic7.9
it worked great then and i need it asap
please...
OS: Windows 10
  •  2
  •  1446
Submitted byahingel
COMMENTS (2)
ahingel
it did crash on some characters with a specific way i created them.
those that exported from blender with solidify modifier and flipped normals with morphs,  crashed.
thankfully i found a solution not using the solidify modifier. but on the previous versions of iclone and 3dxchange worked fine with the first way too.
although still on some of them when i try to export fbx from iclone, iclone crashes (most of the times pops up the message that memory could not be read), but i made another feedback tracker for iclone
i'm sorry i dont want to share these models because its for a client
thank you
Feedback Tracker Admin
Hi ahingel,
I'm very sorry for missing your ticket.It' ok for me.Did 3dxchange crash in all avaters or some?If some,please provide your project file to help us identify the problem.If the file size is larger than 10MB, you can use cloud services such as Google Drive, Dropbox or OneDrive to make the files available to us and put the link in your comment. You can use Private Comment if you want to keep it private.Your help is highly appreciated.
Molly
Reallusion
