Votes
0
Product:
iClone 7
Version:
7.71
Status:
Released in 7.8
Issue 6625
Curve Editor - Can not select transform channels in outliner
To Repro:
1. In iclone, make a new project. (clear scene)
2. Create a sphere primitive shape
3. Set some "move" transform keys on the sphere from the Modify window.
4. Launch Curve Editor
5. Try to select a position channel in the curve editor, like Position.PositionX (Mine will not let me left click mouse select an individual channel.)
I can however, select the individual channel by using the keyboard arrow up/down keys. (This is my only workaround right now.)
I have the same problem on avatar controls.
I can not use the menu: Select Plugins - Curve Editor - Convert to Curve data since it is grayed out.
The position channels are not locked.
There should be no need to do any sampling since I can see the curves, and can get to them through the arrow keys, I just can't left click select the channels directly. This seems like a bug to me, because every once in awhile, a left click will actually select a channel, but then I won't be able to do it again, or select another channel.
Using Iclone v7.71 and Curve Editor v1.31
OS: Windows 10
  •  11
  •  5887
Submitted bytekanimator
1 23
COMMENTS (11)
tekanimator
Thanks all! I'm not actually using iClone at this time now, but really appreciate you following up with a fix for this bug!
Feedback Tracker Admin
Hi Robert,
We're terribly sorry. If your trial version has expired, you can wait for the next patch version (iClone v7.8) and it will reset the trial time. You can also install the ap in another computer, or re-install your system.
Soya
Reallusion
robert_598607
Hi,
Those patches fixed the issue for me thanks.
Will I be able to reset the timeout for my iclone 7 + curve editor trial considering that I've been avoiding evaluating them since hitting this bug?
Regards,
- Robert
Hi All,
We have fixed the bug. Please help me apply the hotfix and try again.
Step1: Please download the TouchScreenHotFix.zip: https://bit.ly/2vJna7I
Step2: Extract the downloaded file to your local drive.
Step3: Make sure iClone and CC are closed.
Step4: Double click on the batch file in the extracted folder to apply the hotfix
    iClone7: IC7ReplaceQtPlugin.bat
    CC3: CC3ReplaceQtPlugin.bat
After you have finished applying the hotfix, please try again and clicking track or category to see if it still happens. Please let us know the result. Thank you so much.
Soya
Reallusion
Hi all,
Thank you for providing the information. We have repeated and reported to RD. Thank you!
Soya
Reallusion
1 23
