Votes
0
Product:
iClone 7
Version:
7.41
Status:
Assigned
Issue 5764
Deleting a mouth shape or keyframe deletes avatar instead
I select my avatar in my Scene box.
I select Object Related Track.
I tick Viseme.
I highlight a lip shape box in the Lips Track, it turns green.
If I right click and select [ Delete Del ]
Lips shape gets deleted.
If I hit the Delete key.
Avatar gets deleted.
I select a keyframe in the Timeline, it turns green.
Keyframe gets deleted.
This does not apply to point shaped keyframes just the long vertical ones.
OS: Windows 10
  •  4
  •  1275
Bug
Submitted byDragonskunk
COMMENTS (4)
Dragonskunk
Included is the video evidence of having the avatar get deleted instead of the keyframe.
When Object selected track is on.
Select an avatar from the Scene list.
Click on a keyframe.
Hit delete.
This possibly occurs when you start on a project changing things in the Scene list as a first action.
Dragonskunk
Yes so can I but did you follow the same procedure as I did?
If you don't follow the same sequence it may not happen.
Dragonskunk
If you don't follow the same sequence it may bot happen.
Feedback Tracker Admin
Hi Dragonskunk,
I can't reproduce this issue.I can delete Lip key by delete key.
Rellusion
