Votes
0
Product:
Character Creator 3
Version:
3.4
Status:
Assigned
Issue 7760
Dial doesn't match morph and can't be undone
Steps to reproduce the problem:
1. Open a project and apply Headshot to the default avatar
2. In the modify tab, select a morph for the head
3. Click in the number field and scroll up to adjust the value
4. Scroll down to set the field back to zero
5. Hit undo shortcut to undo the adjustment
Error: Morph sometimes continues to increase in value even though the mouse wheel is being rolled in reverse. When you try to undo the over-applied morph, undo doesn't work.
Expectation: What's expected is that the software will simply set back to the headshot results by zeroing out any adjustments made in the morph panel.
OS: Windows 10
  •  0
  •  1096
Submitted byH-Band Studio
COMMENTS (0)
