Votes
Product:
iClone 7
Version:
7.8
Status:
Active
Issue 7147
Disconnect HIP rotation from footplacement when footcontrol is activated
Note this is a - feature request !
1. Disconnect the hips movement / rotation / tilting against the feet when foot / ground control is activated and using the gizmo (z) to drag the feet onto the ground
In essence the hips should stop any added translation / rotation when the feet hit's the ground
disconnecting the hips rotation / translation would also solve the other problem where the skeleton get's pulled through the floor if Translate / Rotate is de-selected from the pelvis bone
The problems:
When using foot / groundcontrol and using the gizmo to pull the feet of the character down and when the foot / feet hitting the ground and there is still downwards movement input from the mouse, the pelvis tilt sideways and destroys any minute changes made to the animation, especially when animating the character from one of the left / right side ( in sideview )
When the feet hits the ground, any input from the mouse needs to be blocked / removed so the hips stay at the position it's been set at. This also is true when deselecting the (Translate /Rotate ) pinning from the pelvis and doing the above movement, and the skeleton instead get's pulled through the floor.
This happens with both stock characters in iClone and properly setup characters from 3D exchange
Also note at the very end of the video it shows when keep pushing the gizmo down the foot starts to slide sideways.
( i first use the pink square, but after this it's by the blue arrow, the foot still keeps sliding.)
[YouTube]https://www.youtube.com/watch?v=dbVO8d53OW4&feature=youtu.be[/YouTube]
Second video with a built in character.
[YouTube]https://www.youtube.com/watch?v=q9g7wKVVgCs[/YouTube]
OS: Windows 10
  •  5
  •  1303
Submitted bydoubblesixx
COMMENTS (5)
doubblesixx
Still, why send an answer when it's completely out of context? IC8 is not IC7..
doubblesixx
No this issue is not "fixed" in IC7.. Please don't answer when they are out of context
Feedback Tracker Admin
Hi,
The second test video.
https://youtu.be/TYz5Va_4JTg
Soya
Reallusion
Hi doubblesixx,
This issue has been fixed. It will not happen for iC8. Thanks again for your feedback.
https://youtu.be/iwNARbR_kts
Soya
Reallusion
doubblesixx
Yup, this is a game breaker for sure. This feature would make a huge difference if it's recognized as a problem
