Votes
0
Product:
Character Creator 3
Version:
3.11
Status:
Not a Bug
Issue 6408
Error and can't do anything in my character creator application
i try to open my character creator application many times. and i don't know why i always get notification "Failed to load the file". I also try to reinstall this application 3 times and nothing change. Please help me because my work deadline is near..
can someone help me? and the modify pop up in issue 3 pict can't be close.
OS: Windows 10
  •  5
  •  5914
Bug
Submitted bysiji.solusidigital
COMMENTS (5)
Feedback Tracker Admin
Hi Siji,
We have help you submit your issue to our online support system in order to respond faster and track easier.
Please login your member account and check "Support Ticket" section to see our reply.
For any support questions, please help get in touch with our Support Team via the member login on "Reallusion Online Support Form" as per below link:
https://www.reallusion.com/CustomerSupport/UserEx/QForm.aspx
Thank you for your support!
Irving
Reallusion
Hi siji.solusidigital,
Please move to this folder location if you installed CC3 to default location before. ( C:\Program Files\Reallusion\Character Creator 3\Program\Assets\Creator )
You will see a Default.ccProject, please copy it to %userprofile%\AppData\Local\CharacterCreator\3.0\CCContentManager, and rename as "DefProject.ccProject".
Then, please try to launch CC3 again to see if it's work.
If still not working, here is the description about how to get your system information file. (It only collect your hardware information and Reallusion's product registry profile)
https://www.reallusion.com/FeedBackTracker/Home/HowToGet
Please send the result zip file to us.
Thanks for your help!
Calvin
Reallusion.
siji.solusidigital
this
siji.solusidigital
unfortunately, there is not "DefProject.ccproject" on my CC ContentManager folder..... what should i do?
Thank you for your feedback.
Please try the following steps to restore default project:
1. move to folder location: %userprofile%\AppData\Local\CharacterCreator\3.0\CCContentManager
2. find the project file "DefProject.ccproject" in this folder, and delete it
3. open character creator
Please let me know if it works.
Irving
Reallusion
