Votes
0
Product:
Character Creator 5
Version:
5.03
Status:
Not Reproducible
Issue 12379
Export FBX Mesh and Expression Sequence
CC5 - until 30frame
CC4 - until 90frame
Why does cc4 only send up to 90 frames, but cc5 only sends up to 30 frames.
New toolers can't use it in 5, so I have to use it at least 4, but I can't download it, so what are you doing
OS: Windows 11
  •  2
  •  208
Bug
Submitted bybigg.work2988
COMMENTS (2)
Feedback Tracker Admin
Hi bigg.work2988,
Following up on my previous message—are you still experiencing the same export issue?
If you've had a chance to try the suggested steps (updating to the latest CC5 and re-exporting), please let us know the results. If the issue remains unresolved, providing your .ccProject file would be the most effective way for us to investigate further.
Thank you for your time!
Best Regards,
Jasmine
Reallusion
Hi bigg.work2988,
Thank you for your feedback. We sincerely apologize for the inconvenience this has caused you.
Regarding the "Mesh and Expression Sequence" export issue, we have performed internal tests using both CC4 and CC5 with the "Kevin" character. In our tests, both versions successfully exported the full sequence up to 90 frames (and beyond), and we were unable to reproduce the 30-frame truncation you described.
We suspect this may be related to the Expression Set or the software version. Could you please try the following steps:
Update CC5: Please ensure your Character Creator 5 is updated to the latest version.
Re-export: Load the character that previously exported correctly in CC4 into the latest CC5, and try exporting the Expression Sequence again.
Provide Project File: If the issue persists, could you please provide your project file (.ccProject). This will help our team investigate the specific cause.
If the file is too large, you can upload it to a cloud service (e.g., Google Drive) and share the link with us. You may also check the "Private Comment" option to ensure only our staff can access your files.
We look forward to your reply. Thank you for your patience.
Best Regards
jasmine
Reallusion
