Votes
0
Product:
CrazyTalk Animator 3
Version:
3.03
Status:
Assigned
Issue 2025
Eyes move (1 report 2 separate cases)
Eyes move, resize or change size and angles.
Both G1 and G2
I was making a sprite face (png) on a G3 actor I built and used G2 eyes that worked great. I then added a G2 mouthset and both eye pupils looked to far right after adding mouthset. I had to replace eyeset with same G2 set but they only replaced at half size and left eye look up.(oil can)
Case in Forum
http://forum.reallusion.com/FindPost312369.aspx
OS: Windows 7
  •  3
  •  3049
Bug
Submitted bylesdodds
COMMENTS (3)
Feedback Tracker Admin
Workaround:
Pick character then replace the same character, the character's eyes will be in the correct position.
1. Import character.
2. Pick character.
3. File > Import model > Select the same character.
Reallusion
Thanks for your help.
The issue you mentioned has been verified and we will try to fix it in coming 3.1 patch.
Reallusion
Thank you very much for your feedback.
The issue you mentioned can't be reproduced in our test environment.
Please try to list your working steps as detailed as possible.
Please also provide your project file for further checking. You can use cloud services such as Dropbox or OneDrive to make the file available to us and email the link to feedbacktrackeradmin@reallusion.com.
Your help is highly appreciated.
Reallusion
