Votes
0
Product:
Cartoon Animator 5
Version:
5.02
Status:
Active
Issue 9461
Face3D Tracker absent
Bonjour. Je n'ai pas le plugin Face3D Tracker sur CTA 5 alors que j'ai acheté l'option Facial MOCAP.
Je travaille sur PC Windows 11. Comment me le procurer? Merci
OS: Windows 11
  •  3
  •  589
Submitted byjoelbigot
COMMENTS (3)
r78zj99
hi joe again & thank you to K_Digital
on re-checking that you can re-install -- Webcam Profile for Cartoon Animator 5 if that is the version you are using not the one before.
I went back to the hub & found my products not all listed as before in the older version of the hub. which back then you went to the bottom of the list to install.
so how do you over come this, well see this YouTube video they had made
https://www.youtube.com/watch?v=pNNIt8FbsWw
is useful but doesn't show all listed products!
 Reallusion  have to re-address is issue
1. you can re-install the old versions of the hub (see video) see three versions shown
2. if not above then go to your account manager and find the listing you are looking for.
from Alan
hope I have been helpful
K_Digital
Hello Joe, Make shure you install the webcam profile from the RL HUB after you install CTA5. Its a seperate program you must install. I made the
same mistake thinking CTA would install it automaticly.Scroll down in the HUB while CTA5 is selected, you should find it there. Hope this helps
r78zj99
hi joe
first check on the version you have then try and reinstall it again hope this helps
from Alan
using Reallusion Hub
