Fail to load the Fbx file which was previously exported from Motion Builder 2016 to 3DXchange
STEPS TO REPRODUCE 1. Launch 3DXchange 6 2. Load a Fbx file which was previously exported from Motion Builder 2016
ACTUAL RESULT Error message appeared and fail to load it to 3DXchange
EXPECTED RESULT The Fbx file which was previously exported from Motion Builder 2016 can be loaded to 3DXchange
OS: Windows 10
2299
Submitted byFeedback Tracker Admin
COMMENTS (1)
Thank you very much for your attention.
To temporarily solve this issue, you may need to select a reduced version when exporting FBX file in Motion Builder.
Navigate to Menu > Python Tools > FBX Export, select the reduced version in the popup dialog, then export the file (It would be better if you could choose FBX version lower than 2016).
It's just a workaround to help loading the exported FBX file into 3dx Max.
Reallusion
You are going to edit a submitted issue. This issue will be changed to private draft mode until you click submit again. Are you sure?
