Votes
0
Product:
iClone 8
Version:
8.61
Status:
Not Reproducible
Issue 12206
Failed to open Iclone 8.61
Whenever I try to open iClone 8.61, it crashes. I’ve attached an image showing the error — it always stops at the bottom status bar where it says “Loading Plugin: Motion Live” and then crashes. I’ve tried multiple times and also restarted my PC, but the problem remains the same.
On my second PC, iClone 8.61 opens fine. However, on that PC it sometimes crashes whenever I try to add an FBX motion file (Xsens motion file).
OS: Windows 11
  •  5
  •  623
Bug
Submitted bybhaveshsisodiya1530
COMMENTS (5)
liulifeng
I encountered the same problem. The interface showed the process of loading the Motion Live plugin, and then it exited.But this kind of problem doesn’t occur all the time, and its occurrence is very random.
补充说明:
Feedback Tracker Admin
Hi bhaveshsisodiya1530,
Please use the Reallusion Hub to update iClone to the latest IC8.62 version and try again.
If the issue still persists, please let us know.
Allen
Reallusion
bhaveshsisodiya1530
Hello Allen,
"I have tried all the suggested options, including updating to the latest software version, disabling the firewall, and updating both the graphics card drivers and Windows. However, the problem still persists. I have already shared my system information, but I was unable to share a crash dump file. I followed the instructions provided, but I could not find the file in the (%APPDATA%\iClone\CrashDump) directory. Please help me resolve this issue.
Thank you,
Bhavesh
bhaveshsisodiya1530
I have Tried
Thank you for your feedback.
1) Please update all the software to the latest version through Reallusion Hub.
2) Please temporarily disable your antivirus and firewall, or add iClone to the Windows Defender whitelist and try again.
More info: https://docs.microsoft.com/en-us/microsoft-365/security/defender-endpoint/customize-controlled-folders?view=o365-worldwide
3) Please updating your graphics card driver to the latest available.
Nvidia: http://www.nvidia.com/Download/Find.aspx?lang=en-us
AMD: http://support.amd.com/en-us/download
4) Run "Windows Update" and check whether it is the newest. If Windows is not updated ceaselessly, several issues might occur.
If the problem still persists, please provide your crash dump file and system information to help us investigate further.
https://www.reallusion.com/FeedBackTracker/Home/HowToGet
https://drive.google.com/file/d/1DASCduGVa907ieGZCAHzyRJuR3F5UgaY/view?usp=drive_link
You can use cloud services such as Google Drive, Dropbox or OneDrive to make the files available to us and add the link in your next comment. you can use private comment if you want to keep it private.
Allen
Reallusion
