Votes
0
Product:
iClone 7
Version:
7.8
Status:
Released in 7.91
Issue 7077
Failed to render
In complex scenes, IC7 renders slowly but to the end. When changing to another camera and rendering again, IC7 stops in the middle of the rendering and does not give any feedback. You can see in the Task Manager that the GPU module of the NVIDIA 1060 is no longer being addressed. Success is only achieved when the task is ended and called up iC 7.8 and rendered again.
This only occurred after the update to IC 7.8.
OS: Windows 10
  •  4
  •  1313
Submitted byThorstenMihm
COMMENTS (4)
ThorstenMihm
Hi Molly,
here is the dropbox-Link
https://www.dropbox.com/s/tg0fbqctzleejif/10-Basis-01a.iProject?dl=0
I hope you find the solution of this problem.
Best regards
Thorsten
Feedback Tracker Admin
Hi ThorstenMihm,
I have got it.Thank you.
Molly
Reallusion
ThorstenMihm
I have the same problems with other projects that involve many CC3 characters. Most of the time the rendering succeeds the first time (but not always), if I want to render the same scene with a second camera, the rendering stops in the middle and the iC7 does not react to any command. Rendering is only possible after the task manager has been terminated and called up again.
Can it be a problem with the temp files?
Hi ThorstenMihm,
Can yo provide your project to us?We need to make sure if the reasons are the same.Please attach the file in your next comment. If the file size is larger than 10MB, you can use cloud services such as Google Drive, Dropbox or OneDrive to make the files available to us and put the link in your comment. You can use Private Comment if you want to keep it private.
Molly
Reallusion
ThorstenMihm
Thank you for the feedback. Enclosed the link for the file at Dropbox.
The problem is solved by the way, if I do not start with frame 1 (then frame 239 is over). If I start at frame 10, unlimited rendering is possible. Root cause ?
https://www.dropbox.com/s/kxpbdmgwzok57k4/14-Cockpit-01.iProject?dl=0
Hi ThorstenMihm,
I have got it.Thank you very much.
Molly
Reallusion
Hi ThorstenMihm,
Thank you for your feedback.
Please provide your project file to help us identify the problem. Attach the file in your next comment. If the file size is larger than 10MB, you can use cloud services such as Google Drive, Dropbox or OneDrive to make the files available to us and put the link in your comment. You can use Private Comment if you want to keep it private.
Your help is highly appreciated.
Molly
Reallusion
