Votes
0
Product:
iClone 7
Version:
7.93
Status:
Active
Issue 8273
Failed to use "per Frame"
The movements run at the same speed, regardless of whether I use the realtime mode or per frame (necessary for soft cloth). This works in the projects created before the last update, in all new projects after the last update the Per Frame mode no longer works.
OS: Windows 10
  •  1
  •  1575
Submitted byThorstenMihm
COMMENTS (1)
ThorstenMihm
Here are my comments to the Reallusion support service including a video:
Hello Jana, graphics card drivers have been updated. The problem occurs equally on the "old PC", which previously worked without any problems, as well as on the new PC with iClone freshly installed via the Reallusion Hub. It is interesting that the "per frame" mode works when calling old projects (created before the last update to iClone 7.93), but not when creating new projects after the update. The old PC runs with Xeon processors, the new one with i9 processors (incl. Nvidia RTX 3070). This means that the problem occurred with the update and regardless of whether iClone was already installed or was newly installed
Hope you find a solution as the mode is equally important for soft cloth and physics
Kind regards.
Thorsten
