Votes
0
Product:
iClone 7
Version:
7.2
Status:
Assigned
Issue 5401
Feet going Vertical in iClone 7.2
Hi there! I've experienced an unusual bug a couple of times when animating characters in iClone 7.2
Sometimes when I load the character into a scene, or just at random when I put the character through a walk or run animation, one or both of the character's feet (and legs) will suddenly flip vertically, and point up toward the sky.
I attached a screen grab of the glitch. Any suggestions wouldbe greatly appreciated!
OS: Windows 10
  •  11
  •  4754
Submitted byrowjlan
1 23
COMMENTS (11)
Feedback Tracker Admin
Hi rowjlan,
Because there is a Bridge in terrain,at 800 frames the character is under the bridge.The bridge is regarded as ground,so feet go vertical.
There are two workaround.
1. pick character,open Modify panel Attribute tab,don't check Foot Contact
2. pick Bridge in Scene Manager,Modify menu > Convert To Prop
Reallusion
rowjlan
Hello again - any progress with this?
rowjlan
Hi there, I saw you got the file. Any progress on figuring out what's wrong?
thanks!
Hi rowjlan,
I have got your file, we will check this issue.
Thanks for your help.
Reallusion
rowjlan
Hi, thanks for your reply. The file is too big I realize, so here's a link to it on Google Drive. Let me know if you have any issues opening it.
The "vertical feet" issue appears about 800 frames into the timeline, after the character moves under the bridge.
Thanks!
https://drive.google.com/open?id=1OfWxbme7nfinfO0IQaPSAor-QE50SRaa
1 23
