Votes
0
Product:
Character Creator 3
Version:
3.03
Status:
Not Reproducible
Issue 5657
Fix and improviments for transfer weights option
- fix for boots transfer weights, ok transfer boots weights for males can be a really trouble, while for females is fine for males is really a annoying task, due to the boots deforms to a size for "female" becoming small than the male character feet", in order to make the shoes work on the male character i must make the boot/shoes size 2 or 3 times bigger than the male feet for when do the weight transfer it deform to the male feet size and having to adjust position too, others wearables are fine but the feet one is really a nightmare to adjust.
now improviment.
if possible add more options, like instead of just default cloth, add shirt option, pant option, underwear, sock and a way to make the system know if in the same place is possible to have some "undercloths" like underwear, cuz many times when you are using the transfer weights it can removing others parts if that part not was proper adjusted to support others parts aswell, like if you just add to the naked body a pant and do the transfer and save it, later when you try to add it to a new character it can conflict with others wearables and remove it like removing the shirt or boots or masks or others parts, in order to proper, making impossible to use that cloth with others clothes unless you reset it and do agai a transfer wearing that clothes before transfering the new one.
OS: Windows 10
  •  2
  •  1635
Submitted byEllessarr
COMMENTS (2)
Feedback Tracker Admin
Hi Ellessarr,
Please let us know if the issue still bothering you!
Thanks for your feedback once again!
Reallusion.
Hi Ellessarr,
Thanks for your feedback!
In order to identify this issue properly, please provide your ccProject and capture a screen video to show your workflow.
You can attach ccProject as Zip file in your next comment.
If the file size is larger than 10MB, you can use cloud services such as Google Drive, Dropbox or OneDrive to make the files available to us and put the link in your comment.
You can use Private Comment if you want to keep it private.
Your help is highly appreciated!
Reallusion.
