Votes
0
Product:
iClone 7
Version:
7.3
Status:
Assigned
Issue 5337
Follow Terrain Inconsistensy - rebound
This issue directly relates to Issue 3710 (status Released): https://www.reallusion.com/FeedBackTracker/Issue/Follow-Terrain-and-Projected-Path-Inconsistensy
I stated 2 problems back then:
1. Follow path. I got word it will be fixed in the next release. No need to worry :)
2. Follow terrain. This one is not fixed. The problem persists.
I could use a path for this types of movement. But having Follow Terrain to work properly would be nice too.
Please see freshly made video in IC 7.3, where both problems are clearly displayed (disregard the part about the path):
https://www.youtube.com/watch?v=TWPegJNHohs
Both projects - Terrain and Path are attached (but again disregard Path project)
Open Terrain project and enable Follow Terrain (this setting is not saves with project). Then drag the ARC by Y gismo. It follows a bridge terrain. Then play animation and watch it follows the ground instead of bridge terrain.
OS: Windows 10
  •  1
  •  2530
Submitted by4u2ges
COMMENTS (1)
JasonJ68
I am also having problems with props following paths on terrains.  The prop does not follow the terrain properly.  The prop can be manually corrected along the path (adding rotation keys along the path) but child props ATTACHED to the parent prop do not follow the rotation of the parent prop.
