Votes
Product:
iClone 7
Version:
7.2
Status:
Active
Issue 3770
GI Specular Bounce Strength Factor On Materials
It would be greatly helpful to have a GI Specular Bounce Strength Factor also as a Materials parameter instead of being solely a global GI factor.
This would help having more control on PBR material specular highlights (ie: Eyes Cornea, ..) intensity, which is normally controlled by the index of refraction of the material in a path tracer with the Metal/Roughness PBR shading workflow or by the specular maps in a Specular/Glossiness PBR shading workflow (which is not the iClone "Traditional" material version).
I've attached 2 images, the second one with a boosted global GI Specular Bounce Strength value set to 10 instead of the default value of 1. As you can see it helps having a sense of reflection of the environment in the eyes (which should happen). Unfortunately this also affect all other materials specular of the objects part of the scene, which is undesirable.
OS: Windows 10
  •  0
  •  1798
Submitted byGOETZIWOOD STUDIOS
COMMENTS (0)
