Votes
0
Product:
Character Creator 3
Version:
3.3
Status:
Closed
Issue 7133
GoZ: Zbrush application not found
Steps to reproduce issue
1. install zbrush 2021
2. install character creator 3.3 with pipeline extension
3. press the GoZ button
OS: Windows 10
  •  4
  •  4194
Submitted bymkibria
COMMENTS (4)
gamehatchers
I had this same issue but just moved the GoZ files from C: into the CC3 GoZ folder and viola. It works.
Rhetorikolas
Had this issue, did the same as above, reinstalled, also tried going into Zbrush > Preferences > Goz > Update All Paths (path to Character Creator), and made sure the path to Character Creator was not "Read Only". Seems to have done the trick.
Wolfzone Digital
I had a similar issue with GoZ not working after I installed Zbrush 2021. I fixed it by going to the Goz_for_ZBrush_Installer_Win.exe file and ran it. It should be located in: C:\Program Files\Pixologic\ZBrush 2021\Troubleshoot Help
Hope that helps
Feedback Tracker Admin
Hi mkibria,
Did you have the old version of ZBrush ( ex : 2020 ) to see if the issue still the same?
And, did GoZ function work on Maya or other pipeline software?
Also, please check this ZBrush folder to see if there have .exe file such as attached image.
( C:\Users\Public\Pixologic\GoZBrush )
Thanks for your help.
Calvin
Reallusion.
