Votes
0
Product:
Character Creator 5
Version:
5.12
Status:
Assigned
Issue 12684
Headshot v3 Bug – Project from Image Not Generating Photo Textures
Hello Reallusion Support,
I would like to report what appears to be a bug in **Headshot v3** involving the **Project from Image** feature.
When I use a **Headshot v3 mesh** and select **Project from Image**, the source image does not appear to be used to generate the expected textures. I have attached three images for reference, including one showing the results I receive when using Headshot v3.
I have already worked with support and tried several troubleshooting steps. Unfortunately, none resolved the issue. For example, I moved the **Subdivision** slider to zero and clicked **Delete Highest SubD** as instructed, but **Project from Image** still did not generate the expected textures.
For comparison, I closed the program, reopened it, and performed the same process using **Headshot v2**.
There is a significant difference between Headshot v2 and Headshot v3. In Headshot v2, selecting **Project from Image** generates the following texture channels:
* **Photo Diffuse**
* **Photo Normal**
* **Blend Mask**
These channels can be seen in the attached Headshot v2 image. When I perform the same **Project from Image** process with a Headshot v3 mesh, these channels are not generated. The attached images also show a noticeable difference between the resulting characters.
When I first encountered this issue, I thought having Headshot v2 installed alongside Headshot v3 might be causing a conflict. To eliminate that possibility, I completely uninstalled Headshot v2 from my laptop and tested Headshot v3 again. Unfortunately, the problem remained.
Since the same **Project from Image** workflow functions correctly in Headshot v2 but does not produce the same texture channels in Headshot v3, I believe this may be a software bug in Headshot v3 rather than an issue with my workflow or settings.
I would appreciate it if the development team could investigate the difference in how **Project from Image** is handling texture generation between Headshot v2 and Headshot v3.
Thank you.
OS: Windows 11
  •  0
  •  21
Submitted byblackhawk
COMMENTS (0)
