Votes
0
Product:
iClone 8
Version:
8.01
Status:
Released in 8.1
Issue 8729
Iclone 8 performance issue
Currently iClone 8 has very big performance problems when editing animations.
The more animations there are in a project the more iClone becomes unusable.
Steps to reproduce issue:
1. Open iClone 8
2. Add a character, 'Motion Dummy_Male'
3. Create a clip from frame 0 to 180
4. Add 2-3 keys of arm or leg movement
At this stage iClone reacts quickly, switching to play/pause, moving an arm, takes less than a second
5. Change the TimeLine range to 40000
6, Copy / Past current clip every 200 frame to fill the TimeLine
At this stage iClone starts to become slow, switching to play/pause, moving an arm, takes several seconds
7. Remplace current actor with another actor ( Base/Neutral Male ) (or another one)
8. This operation take a long time.
Now iClone is very slow.
9. Create a new project
10. Add a real character ( Base/Neutral Male )
11. Take a clip from the library which is about 200 keys long
12. Change the TimeLine range to 40000
13, Copy / Past current clip every 200 frame to fill the TimeLine
14. Delete all clips, except the first one
15. Use 'Sample Motion Clip' on the first clip
16. Copy / Past first clip every 200 frame to fill the TimeLine
17. Switch to play, pause, play, pause
Now iClone no longer responds.
Note. When working with a real project, containing a lot of clips and keys, it becomes impossible to work properly, any action takes a long time.
Note 2. The size of the iClone project is increased from 150Mb to 650Mb after step 7
Note 3: For steps 14 to 16, make sure you have time to spare :)
Operating System: Windows 10 Pro 64-bit (10.0, Build 19044) (19041.vb_release.191206-1406)
Processor: AMD Ryzen 9 3900X 12-Core Processor (12 CPUs), ~4.16GHz
Memory: 65536MB RAM
Available OS Memory: 65450MB RAM
Page File: 49426MB used, 23139MB available
DirectX Version: DirectX 12
Card name: NVIDIA GeForce RTX 2080 Ti
OS: Windows 10
  •  0
  •  2134
Submitted bySaeder
COMMENTS (0)
