Votes
0
Product:
iClone 7
Version:
7.91
Status:
Released in 7.92
Issue 7860
Iclone crashes when trying to break/split saved i-talk file
1. Create a facial animation with visemes and/or expressions
2. Save out an i-talk or motion plus file
3. Import the saved i-talk or motion plus file
4. try to create a break in the file into two pieces
5 . IClone crashes
OS: Windows 10
  •  3
  •  2312
Bug
Submitted bye1_scheer
COMMENTS (3)
e1_scheer
Hi,
1.
So I've narrowed down the problem to splitting a acculips clip without words.  If you split an acculips clip that has words in the actual text window
than you can split the clip fine, but if you take the words away and then try to split the clip, Iclone crashes.
2.
The second part of the problem is harder to track down, but I've experienced cases where  when you save the acculips clip as an I-talk file
and then load it in aain the words in the text window sometimes get lost. As there is no way to tell from the timeline when you try and split a similar
i-talk file iclone also crashes for the same reason as point 1
I've attached a video illustrating the first part of the problem
Hope that helps.
Feedback Tracker Admin
Hi e1_scheer,
1. I misunderstand what you said.Thank you for your video.I can repeat it.
2. The second part of the problem: Did it just happen in some audio or some project or after some opration?
Molly
Reallusion
Hi e1_scheer,
I can break i-talk or motion plus file whether there are acculips words in  i-talk or motion plus file.Can you capture a screen video about this issue, put it on the YouTube, and add the link in your next comment?
Molly
Reallusion
e1_scheer
I think the issue is that iclone doesn't save out the acculips words with the i-talk file
and probably related to the other problem I raised about i-talk/motionplus/fbx not
saving or exporting out the talking style information.
These new features are just not production ready and should have been tested more
thoroughly before putting them out there.
