Votes
0
Product:
Character Creator 3
Version:
3.11
Status:
Not Reproducible
Issue 6316
Imported OBJ do not centered to figure properly
When you import an OBJ that you have modeled around an CC3 imported figure, when you import it into CC3, it doesn't position properly. I export the CC3 figure --it doesn't matter if it's male or female, but I import it to my modeling program and lock it from being moved, scaled, rotated or otherwise altered before I start modeling. I model the new piece of clothing, taking care to observe any poke through issues before importing it into CC3. When I import the Obj as an Accessory, it is never in the correct position. I usually end up having to rotate, scale and use Iclone tools to try to fix the issues. Also, I NEVER model clothing at the exact same size as the model. I always scale it up along the normals to make sure that it's not the same size as the CC3 figure.
OS: Windows 10
  •  2
  •  2585
Submitted bywill2power71
COMMENTS (2)
Feedback Tracker Admin
Hi will2power71,
Please let us know if this issue still bothering your workflow?
We need further information to identify the issue, have you check which bone did the cloth attached after you create them into CC3?
Calvin
Reallusion.
Hi will2power71,
Thanks for your feedback!
Can you capture screen video to reproduce this issue?
You can upload your video to YouTube, and attach the link in your next comment.
Thanks for your help!
Calvin
Reallusion.
