Votes
Product:
iClone 7
Version:
7.93
Status:
Assigned
Issue 8245
Importing ABC ( Alembic ) files from Marvelous Designer crashes iclone!
Hi, I have a project with a prop (dress) in Iclone7 and the same dress was animated (simulated) in Marvelous Designer - when I try to import the alembic file from MD ( with prop selected, without prop selected, with import function or python script) -> Iclone7 always crashes - no message, just gone!
I uploaded the abc file and obj of the prop as well as the project file (link in the txt file I attached here) please help me out with my alembic workflow with iclone! Thnx
OS: Windows 10
Duplicate Issue:   Alembic import crash
  •  5
  •  3225
Submitted byAppventa
COMMENTS (5)
Appventa
Hi there,
After a lot of trial and error, I found out that there is an option in the export settings of Cinema4D to export alembic files, that can be imported in Iclone7 without crashing:
In the export settings for Alembic, check the "Merge Generated" checkbox at the bottom. That ABC then can be imported to Iclone, Unreal, and other DCC - as far as I have tested it.
So my workaround at the moment is to open the alembic files from Marvelous to Cinema, then re-export an Alembic from there and import it in Icclone - :)
Hope that helps.
Best, Theo
Feedback Tracker Admin
Hi Appventa,
Thank you very much for telling us.You are so nice.
Molly
Reallusion
karipori28_090816
everytime in import alembic to iclone 7, i get this error
Hi Appventa,
I'm very sorry that I export cloth without motion and can import it to iClone,when I export the cloth with motion,iClone will crash.I choose Alembic(HDF5).
Molly
Reallusion
Appventa
I have tried exporting both alembic options - ogawa seems to work better with other DCC ... with AND without UVs & textures, thin & thick... iclone always crashes.
-> how do you manage to export from MD and import to IC ? -> can you make a capture with your workflow?? that would help
Hi Appventa,
We can import Marvelous Designer's abc to iClone.Can you capture a video for your operation in the Marvelous Designer,until you export abc?Thanks.
Molly
Reallusion
