Votes
0
Product:
iClone 7
Version:
7.41
Status:
Active
Issue 5333
Iray Tonemapper Template - Need an easy way to reset to default/none
On the Tonemapper Template menu, if you pick one, there is no obvious way to return it to the original default setting.
I had to open a new project to discover that the default template is "dscs315," which appears a long way down the list, and a user would never guess that was the original template.
REQUEST:
1) Name the default template to be "None" (or "Default," but "None" is more clear)
2) That should be the very FIRST template in the list. Since the list is currently in order of a simple ASCII sort, prefix "None" with a Space or Hyphen if you need to in order to make it be the first one on the list.
OS: Windows 10
  •  1
  •  1457
Submitted byjustaviking
COMMENTS (1)
I would like to add 2 more related problems with tonemapper profiles:
1. Highlight color is BLACK. It is almost impossible to spot on a dark gray background. Highlight color should be green to go with the iClone UI template.
(Slide 1)
2. While image is highlighted when clicked and the respective camera profile is selected from a drop-down, the opposite does not work.
Proposal: When camera profile is selected from a drop-down list, it should highlight the corresponding image and
if the image is outside of the visible area, it should scroll up or down automatically.
