Votes
0
Product:
iClone 7
Version:
7.0
Status:
Released in 7.3
Issue 3373
Jade's mohawk hair becomes transparent with smoke or fog particles in background.
I'm using Jade in a scene. She has elaborate hair with a Mohawk, which becomes partially transparent when there are smoke or fog particles in the background.
The image hair_and_smoke.jpg shows what happens.
The image hair_normal.jpg shows what the hair should look like.
I have tried adjusting Alpha Threshold and although this gets rid of the transparency it also affects the quality of the hair so it's not really a solution.
The issue is easy to reproduce (Render option must be set to "High"):
1. Load Jade, e.g., at [0.0.0]
2. Behind Jade, load the Big Smoke particle effect, e.g., at [0,500,0].
3. Have the camera look straight at Jade.
4. Play the scene. The Mohawk will disappear.
For the result see this video: https://www.youtube.com/watch?v=ZBE4S0bgs6M .
My GPU is a GTX 1080 with the latest driver (382.53).
OS: Windows 10
  •  8
  •  4213
Submitted byanimagic
1 2
COMMENTS (8)
Feedback Tracker Admin
The issue was solved, will be released in the coming patch.
Reallusion
Here is a link to a simple test project to show the issue: http://www.virtualrealist.com/uploads/hair_and_smoke_and_dof.zip .
Interestingly, user toystorylab found that by changing the particle blend mode to "Addition" and having DOF enabled, the issue does not occur.
See this post: https://forum.reallusion.com/FindPost366770.aspx .
Raphael, unfortunately it is still not fixed. See attached image.
RL, this is really a major problem that should be given some priority.
raphaelbertani
I'm with the same terrible error. There is not a solution yet?
Just as a reminder, this is still an issue in 7.2, at least with the legacy particles.
1 2
