Votes
0
Product:
iClone 8
Version:
8.41
Status:
Released in 8.42
Issue 11311
Max Texture Rendering Output Both iClone and CC4
Since the last update when I export a file Render Both in CC4 and iClone if I use the Max texture size output the resulting Image or Move Regardless of the format of the file chosen it comes out without the texture see attached images. Now I'm not attaching the movie because it's way too large but the resulting movie from the instant you click render, it starts rendering frames that looks like the error images that I'm attaching. Now if I Don't check the box in the render settings that says Max texture size it comes out correctly textured. I used to be able to choose this before the last update this just started both in iclone and CC4. Once the process has removed the texturing in the program the only way I can restore the textures is to relaunch the program. Can't find a way to refresh it without restarting the program.
OS: Windows 11
  •  4
  •  652
Submitted byLairdPaul
COMMENTS (4)
mattyboy1509
Me too took me a while to figure out which setting it was .....
StormGrrl
I'm experiencing this too. Fortunately for me, I was on a brief hiatus from the animation process for our film when it started. I'll be following up on this over the next few days as the pause in action is over, and I need to be rendering with full textures full speed ahead asap. I'm sure the Reallusion team will fix it or roll back the update. We'll see what they do.
LairdPaul
Lanzaboy, Thanks for the work around.  I have been able to work around it, but my concern is not being able to export or create movies with the same high resolution that we were be able to produce and is no longer available to us. So, I hope the Reallusion will have a fix for it.  This worked correctly for me before the recent update.
LairdPaul
Lanzaboy
Exactly the same for me. Not always 'max texture' can also be 'include glow in alpha' (for png sequence). Work around for me is to first change the viewing mode to get the textures displaying correctly in the editing screen then without either 'max texture' or 'include glow in alpha' try to re-render. Its a pain because it's only some textures that drop out so it may not always be obvious what is missing when watching the render.
(RTX4080 SUPER: 128GB RAM: RYZEN9 - Win 10 latest updates. Nvidia Game Driver - 552.44
