Votes
0
Product:
Character Creator 4
Version:
4.32
Status:
Not Reproducible
Issue 11269
Morph Slider System may be severely broken
I havent used morph sliders for a moment, today i discovered the below.
Do the following:
- Load a character
- Goto headshot Skull - (or any other sliders)
- make a few adjustments like size and height
- Create morph slider
- Slide created morph slider down to zero
This happens to any character you load, any head morph slider thats created when turning down to 0
turns out in the same funny shaped face.
CC4,32 Win10/Win7 Gtx1080ti, 32Gb Ram. also Tested CC44 which does the same.
De-Installed Headshot 2, deinstalled CC4, Made data Base reset with RL bat files, re-installed everything;
no change. Meanwhile I am sitting here more debugging then using the software. Not good !
See below pictures and attached ZIP.
EDIT:
The manual gives the impression of having the slider properly working immediatley after creation
https://manual.reallusion.com/Character-Creator-4/Content/ENU/4.0/06_Customizing_Morphing_Sliders/Creating-Head-and-Body-Morphing-Sliders.htm . When deleting the char and reload it, THEN the slider works as expected . Perhaps worth fixing or at least mention it in the manual.
This took me almost a whole day to find out. Not good.
Regards
Mr. Betatest Nr1
OS: Windows 10
  •  3
  •  653
Submitted byK_Digital
COMMENTS (3)
Feedback Tracker Admin
Hi K_Digital,
I'm sorry that I made a mistake in two creating slider functions. I use "Create Head & Body Morph Sliders",after creating slider,the silder value is 100.Can you capture a screen video to us?
Molly
Reallusion
K_Digital
Thanky our for the answer,
I think the issue can be ignored, but you should mention in your manual that the created morph is not availiable immediately after creating the morph. As far i i have learned now is that the project needs to be reloaded.
K_Digital
Hi K_Digital,
It will change to neutral base character when you set slider value to 0.If you want to Kevin when slider value is 0,you can do as my video.
Molly
Reallusion
