Votes
0
Product:
iClone 8
Version:
8.0
Status:
Released in 8.01
Issue 8444
Motion Blur Problem
I found a motion blur problem with one of my characters.
It manifests itself in Realtime / By Frame mode and also when exporting video.
Characters, pants, etc. have 4K bitmaps
Only the shoes have 8K resolution.
I've tried changing the motion blur settings, but only the shoes always have faulty motion blur.
Next one. Same Motion Blur problem.
Now I definitely know the reason is not the 8K resolution.
The shirt is 4K just like the pants.
Again, abnormal motion blur only on the shirt. I'm guessing about 10x stronger Motion Blur than the other objects.
My graphics card is an NVidia RTX 3060 12GB
OS: Windows 11
  •  10
  •  2989
Submitted byReMark3Dcz
1 2
COMMENTS (10)
WeiChien(RL)
Hi ReMark3Dcz,
Thanks for clarifying my guess. We will try to fix this issue ASAP.
Sincerely,
Weichien
Reallusion
ReMark3Dcz
@WeiChien(RL)
 I just tried the same object with a moving figure in IC8 and the problem does not occur with Smooth Mesh on or with tessellation.
The problem is only in CC4 and only with the Smooth Mesh feature enabled.
Tessellatin in CC4 + motion Blur works without any problem.
So only objects with Mesh Smooth enabled in CC4 produce Motion Blur rendering errors
ReMark3Dcz
@WeiChien(RL)
Have a good day,
I own IC8, but so far, as I wrote, this problem is in CC4. I will try it in IC8 today and let you know if motion blur errors appear there too.
To try it, just download these products in trial version:
problem with the scythe - https://marketplace.reallusion.com/rm3d-ratguy-clothes
problem with shoes - https://marketplace.reallusion.com/rm3d-nord-warrior-338763
Anyway, you've figured out why the problem occurs. Smooth Mesh is applied to the problem objects. When I turn it off, the motion blur works fine.
Does this mean that Motion Blur cannot be used for Smooth Mesh and Tessellation?
 Thank you very much, for now I will avoid using these functions when I want to use motion blur.
But I hope this will not be the final solution and you will be able to solve this problem.
Thank you very much for your fast and great support
Have a nice weekend
Martin Reznicek
WeiChien(RL)
Hi,
Thanks for using iClone8.
We are trying to reproduce your issue.
Did you set Tessellation or Open Subdiv for the cloth which generate the abnormal motion blur result? Or did you give it a displacement texture?
Sincerely,
Weichien
Reallusion
ReMark3Dcz
Private Comment
luke (RL)
Private Comment
1 2
