Votes
0
Product:
iClone 8
Version:
8.01
Status:
Released in 8.2
Issue 8701
Motion Blur does not works if DOF enabled on camera
I don't think it's a bug, more a limitation of IC8, but it definitely makes the user's job worse that when the camera uses depth blur, the motion blur intensity slider doesn't work. IC 8 motion blur is really nice, but if i need to use it with DOF, i have to work in a separate layer anyway.
OS: Windows 10
  •  2
  •  1539
Bug
Submitted byFreddymusic
COMMENTS (2)
Freddymusic
this is a project file with the problem: http://www.tbklub.hu/bitsonic/blurtest.iProject
I turned of soften edge and correct transparency in the preferences menu, and motion blur worked with DOF, but the end result was very poor quality. You can see this on the second picture.
On the first picture you can see the problem. The strange thing is that I created a completely new simple project file with a background and a moving object, but there was a good motion blur with DOF. I don't know what is causing this problem, but almost all of my project files are causing this problem.
Feedback Tracker Admin
Hi Freddymusi,
I have got it.Thanks.
Molly
Reallusion
Hi Freddymusi,
Thank you for your feedback.Please provide your project file to help us identify the problem.If the file size is larger than 10MB, you can use cloud services such as Google Drive, Dropbox or OneDrive to make the files available to us and put the link in your comment. You can use Private Comment if you want to keep it private.
Molly
Reallusion
