Votes
0
Product:
iClone 8
Version:
8.31
Status:
Assigned
Issue 10818
Motion direction control, when editing the rotate, adds translate. so characters keeps teleporting further and further away.
I'm not sure what triggers it, but at some point it starts happening.
rotating with the gizmo, or clicking on the small arows in the rotate values in the popup panel, will make the character teleport 20 meters in a direction, even a 0.1° rotation triggers the bug instantly. every rotate interaction adds these 20 meters so the character quickly fades away in the distance.
The bug can be seen here, just select one character the CHARACTER collection, and use motion direction control to rotate any of the clips:
https://www.dropbox.com/scl/fi/n33p1g73jxezl5f3bk3ls/GoatHunt_006_SHAD_INTRO_RUN.iProject?rlkey=ux3qgdxd9w9otyvyc4mzkzrkb&dl=0
OS: Windows 10
  •  4
  •  572
Submitted byanimaliok
COMMENTS (4)
animaliok
Private Comment
Feedback Tracker Admin
Hi animaliok,
I have got it.Thank you very much.
Molly
Reallusion
Hi animaliok,
Thank you for your project,but I don't have permissions, can you give me permission?Thanks.
Molly
Reallusion
animaliok
Hi, thanks for your answer, I couldn't find again a file where this issue appears, but it was frequent a few month ago, maybe the latest iC version solved it, or it will pop again.
We had another issue with the motion direction control, when a rotation value was randomly going to infinite numbers, also teleporting the character away.
I will save the file in a permanent location next time it happens so dropbox doesn't loose it.
Thanks !
Hi animaliok,
Can you provide your project file to us?
Molly
Reallusion
Hi animaliok,
We can't repeat it.Can you provide your project file to help us identify the problem?Please attach the file in your next comment. If the file size is larger than 10MB, you can use cloud services such as Google Drive, Dropbox or OneDrive to make the files available to us and put the link in your comment. You can use Private Comment if you want to keep it private.
Your help is highly appreciated.
Molly
Reallusion
