Votes
33
Product:
iClone 8
Version:
8.22
Status:
Active
Issue 9505
Need option to disable auto-keyframing. Also, any property that's animated should be visible in the Timeline.
Need option to disable auto-keyframing. Most animation applications don't automatically add a keyframe every time you move an object like a light or camera or change the color of a material. At a minimum, there should be an option to turn that behavior off. Can't tell you how many times I've moved a light only to realize I wasn't at frame 0 when I did it. Then hit play and the light starts moving around. Not good.
Also, any property that's animated should be visible in the Timeline. As it is (for example), you can inadvertently add a keyframe for material color because you changed its value, but when you go to the timeline, there's no indication of what the change was and no way to edit it.
BTW: The options in your "General tag" section (apparently a required field) on this Feedback form are too limited and don't include obvious general categories like "Animation" or "Timeline"
OS: Windows 10
  •  11
  •  2936
Submitted bybarca-8
1 23
COMMENTS (11)
primaveranz
Please at least explain why you are unable to do this. It is the single most annoying aspect of trying to use iClone.
radu_276037
This would be a massive productivity boost and is a very standard option in all other 3d packages.
bradmballew
Yes please fix this. This should be a basic feature of any animation program.
r.palermo101
They absoultely DO NOT care about their users. Have you tried their "learning" tutorials? I am so made I invested so much damn money into this program
panbeep
Hello Reallusion. This is the most frustrating issue in iClone. How can you do this to us???? Every time I change something I don't want to animate the app adds keyframes.  Please Fix this immediately!!!
1 23
